To anyone who is making SVCDs/VCDs for their Pioneer 343...
When I make xvcds with higher bitrates my Pioneer display says something like PBC and does not show time.
When I encode xvcds with a higher resolution (352x480) I end up with the movie playing in a small box on the screen.
Using TMPGenc or CCE with TMPGenc as frameserver.
Help?
352x576 (i have mostly PAL) works fine for me, are you sure you did anything right? It will show PBC PLAY on the Pioneer as soon as you put a VCD/SVCD/X(S)VCD in it. That's normal. PBC, btw., stands for Playback Control and simply put it means that you can forward and rewind etc. Good tip: Read the manual of the player. It says something about VCD here and there.
The only problem I experienced with my Pioneer is, that it has it's fair share of problems with high bitrate VCDs.
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
Hi!
Just to add my bit .....
I'm having probs with my new DV-444 - seems like high bitrates are messing it up too!
Sue xxx. -
Is there a way to have the time displayed instead of PBC?
If I'm making an xvcd with a resolution of 352x480 and bitrate of about 1800, are there any special settings I need to change in TMPGEnc or Nero before burning so that I don't end up with the small box display?
Should I choose 'standard vcd' 'non-standard' or something else? -
YES! Instead of pressing play (>
press track forward (>|)
Found that out by accident... -
the reason they show in half the screen is probably because the SDE flags are set improperly. if you did this by capturing in realtime MPEG, you can fix it with the 'fix12c' program (search the forums, i've explained this many times). otherwise, try and choose the correct aspect ratios for both source and destination in TMPG or whatever encoder you use.
To get rid of the PBC and see the time displayed, I push the numeric key "1" on my Pioneer DV-343 remote control (as if I want to play track #1).
The track number 1 is display along with the play time.
However, the play time only match with 1150kbps (VCD bit rate). That means for XVCD encode at higher bitrate, the time counter will advance faster than your clock. For example, for XVCD at CBR 2300 kbps, the Pioneer DV-343 will advance the time counter twice faster than real clock.
This strange phenomena does not happen for VBR SVCD.
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer DV-420V
By Vasilii in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Jun 2009, 08:28 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
