Ok I know this probably should go in newbie/general forum but this is related to dvd recorders.
I've had my Liteon settop dvd recorder for awhile now. I like it a lot.
One thing I don't like is labeling RW discs. I have a stack of 25. I've labeled some generically like "DOCUMENTARIES", "SPORTS", "MOVIES", etc....
The problem I end up with is when a disc is near full and I have a show I want to record right away I plop in an empty RW and set the recorder. But I don't want to label it becuase then after I erase it the labeling is wasted and will fill up very quickly - the label surface that is.
Now I do a lot of capturing on my pc where I have a lot more space for recording and labeling isn't a problem. BUT when I use my dvd recorder I'd like an eraseable method for labeling the discs. At least with videotapes you could always use a pencil when you're in a crunch to get it labeled for later use.
Is there something suitable out there or do any of you have an alternative labeling method? Suggestions are welcome.
Results 1 to 18 of 18
Would't that be a contradiction? A sharpie is a permanent marker. If it were erasable, it would not be a permanent marker.
Believing yourself to be secure only takes one cracker to dispel your belief. -
True but I'm looking for an alternative.
Would eraseable pen work or would that damage the disc??Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
There are some that write on the board in schools, there may not be a tiny tip one. Some other brand have them like Crayons. There are removable stickers too for CD/DVD 's. I write on the case sleeve. Also check this
http://www.erasable.com/ -
Originally Posted by INFRATOMBelieving yourself to be secure only takes one cracker to dispel your belief.
Originally Posted by Dv8ted2
BTW yoda, maybe you can report yourself and have this moved to Media or even OT. It's Recorders, not recordables :P -
Hey thanks jjmon! Thats what I was thinking of. I'll have to make a stop at office depot or office max and look at those.
I dip a tissue in isopropyl rubbing alcohol and rub lightly over the writing. The ink dissolves and is absorbed by the tissue.
Maxell makes a permanent marker eraser pen. The model number is CD/P-ER. The web site link is listed below.
http://www.maxell-usa.com/content/pages/Page.asp?Section=products&department=maintenan...Product=190712 -
MULTIMARK: IDEAL FOR CD
The new Multimark - the allrounder that writes on most smooth surfaces. In two versions: water resistant/ permanent and water-soluble/ non-permanent.
With integrated special eraser. Clean and optimum results on most smooth surfaces.
http://www.faber-castell.de/docs/index-news.asp?id=10957&domid=1010&sp=E&addlastid=&m1...13129&m4=10957
JSBIt will be very hard to defend your rights, when you don't have any. -
This will work too, but not perfactly. When I make a spelling error, I use the sharpie as an eraser. The ink will disolve itself. In other words, I make like a smear of black ink, and use a toilet paper to clean up the wet smear. You never get it perfact, but pretty close.
I belive acatone (aka fingernail polish remover) works too. It removes graffiti marker off my truck. Very strong stuff.
Thanks Mike -
Originally Posted by mike1061
Eeeeeeeeeeeew! -
Originally Posted by jyn999
Darryl -
I use slim jewel cases and I write on post-it notes, for RW discs.
I was going to write the same thing last night but logged off instead. I use regular CD cases that I had bought some DVD Maxells in long time ago. The discs fit better and the post-its are the quickest erase I can find. rip it off , put on a new one.
How can I make SD look like HD?
By Nuke Shower in forum EditingReplies: 4Last Post: 29th Jul 2008, 13:53 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 16:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
Make my PC into a Tivo?
By Xenogear900 in forum DVB / IPTVReplies: 5Last Post: 15th Nov 2007, 13:09 -
I want to make a DVD..
By Nyntendou in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2007, 11:33
