Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Guest
    Hello i have an problem i want to see my Divx movies on my Tv but when i send the signal out to the tv i goes black and white? I have a GetForce2 Mx/Mx 400 64Mb and i have windows Xp on my computer and i are using a S-video cabel.
    I have the new drives from Nvidia but i dont work relly need help.
    Jul 2001
    usa
    sometimes this can happen when the s-video connection is loose, or sort of hangs at an angle to the input, try wiggling the cable if it goes color to black and white, then that would be the problem, if it's not that then i don't have any other tips.
    pants
  3. Could be that your movie is NTSC and your TV is PAL or vice versa.
    This will result in a b&w picture.
