Hi
Suzie gets married. The family video's it on VHS (PAL). Not all the family have video machines, so they ask me to convert it to DVD.
I capture the video using Pinacle Studio 9, VHS mode so no problems with frame-drop. Convert it to MPEG-2 with MainConcept, at a CBR of 6000 because it is short enough to fit on one disc.
Clean up, edit in Pinacle Studio 9 and "Make Movie". I then use TMPEG DVD Author to convert to DVD format and add chapers at 3 minutes intervals.
I then use Nero 7.0.0.0 to burn it to DVD-R. If I play it on my LG DVD-Video Combo there are no problems.
If Uncle Fred plays it there is a constant slight lip-sync problem. Is it me, the format, or his DVD-player?
Thanks,
Nigel
That should shorten the working time.
Because I know the video will fit on 1 DVD the first time I encode I use a cbr, and then use the same cbr when re-doing in Pinnacle, which then just copies the bits that don't have cross-fades, so there is no re-encodong, just copying time.
It still does not solve my problem where my DVD plare has no lip-sync problems and others do.
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 09:23 -
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 12:31 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 10:16 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53
