can anyone vouch for an app that converts divx to MP4 (iPod) without annoying audiovidual sync issues? I batch-encoded some files using videora overnight, and looking at them now, I see the further I get into playing back the file, the bigger the a/v sync issue becomes. 30 minute tv shows seem to hold out ok, but 2-hour movies get pretty bad. I have not yet played these back in my iPod yet so for all I know the problem is not present on the device but I kinda doubt it.
Thanks -
Brian Mc
I would check those Divx/Xvids with GSpot for MP3 VBR audio. That will cause the type of problems you describe. If you find it: http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm
Then you can mux the new MP3 CBR back into the video and try encoding it.
The other common cause of sync loss is missing or corrupted video frames. VirtualDub can check for these also. -
I appreciate the reply.
But I think I jumped the gun in posting. After a bit more scouring of the forum archives, I found this app called SUPER. Goofy UI, great app. It's getting the job done in spades - no a/v sync issues, correct aspect ratio, manageable file size, etc. very good app for what I need to do.
Incidentally, I encoded my Divx files myself in AutoGK and I used 128 mbps CBR MP3 as the audio in all of them. So I chose not to pursue that potential issue.
Thanks again -
Brian Mc -
I read elsewhere that the 3gp app doesn't respect original aspect ratios though.
Your thoughts? -
i've converted alot of stuff with it. i really don't know anything about if it messes with the ratios but everything looks good when i play it on my tv.
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 02:10 -
Batch Convert Avchd To Divx Or Ipod
By leo_bassani in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 16:07 -
Divx sound sync issues
By hotsalt in forum Video ConversionReplies: 1Last Post: 11th Apr 2008, 14:18
