I have a MKV file with two soft coded subs (rendered in player, not permanent) that are displayed simultaneously...one on the top, one on the bottom (bottom for main dialog, top for clarity due to differences in culture). Is there a program I can use to convert the MKV file to a DVD compatible MPEG-2 program stream that does not overlap the subtitles while displaying them both?
mkvextract everything and then convert....with for example convertxtodvd.
or try avi2dvd, it claims to support mkv...but don't know if subs are supported. -
alright, convertx kept on rejecting my subtitle files...anywho, after some trial and error, this is what i did:
1) demuxed AAC audio/XviD video/subtitles using mkvextract (cause vdubmod can't properly demux MKVs)
2) ran AAC through Quicktime/iTunes set to export as 48khz 16bit stereo PCM WAVE
3) loaded XviD into VdubMod, used the TextSub filter and loaded the subtitle (it turns out that vdub made an error and the subs were exactly the same thing (not what i thought), one in UTF-8, and one .ASS)...hardcoded it into the video/frameserved to Mainconcept mpeg encoder to get the MPEG-2 video file
4) loaded the wave into sony vegas and rendered it as a stereo AC3 file at 192kbps
5) loaded TMPGEnc and muxed the AC3 and MPEG-2 together to make the program stream.
theres probably an easier way, but i liked having control of every single step...and it worked out in the end.
Convert MKV with .ass subs to mp4 with ffmpeg
By bearnado in forum Video ConversionReplies: 2Last Post: 1st Mar 2012, 03:21 -
Using Mkv2vob to convert mkv to avi with subs.
By spunge85 in forum Video ConversionReplies: 2Last Post: 11th Jan 2010, 15:21 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
Help!!! Need to Convert Soft Subs into MKV to work with WDTV
By carlos1969-1 in forum DVD RippingReplies: 9Last Post: 6th Apr 2009, 12:17 -
convert mkv with subs to avi (ac3 audio)
By Substance001 in forum Video ConversionReplies: 11Last Post: 7th May 2007, 19:37
