In encoding to MPEG DVD how much of a speed advantage does TMPEGEncExpress offer over TMPEGEnc or TMPGEncPlus? I know it hangs on a number of things like speed of system etc., but given the same file, does the Express version offer a real advantage? Has anybody ever done a comparison of the encoders?
not that big difference but I haven't tested latest tmpgenc xpress 4...
if you want faster mpeg encoders test convertxtodvd or quenc or mainconcept mpeg encoder. -
Without having played with it extensively, I believe that the encoding engine is the same or similar as TMPGEnc and TMPGEnc Plus. The Express side of things is more to do with the setting up of the encodes with the wizard-based interface.
If in doubt, Google it. -
I have tmpgenc plus 2.5 and express 3 and both are comparable in speed. Express' noise filter has more options but can be set high and be much slower. Without the noise filter, it is very similiar, or maybe just faster.
I have used AviDemux using its lavc DVD and set the Quantizer setting to 2 and it is much faster and produces smaller mpeg files. Quality is very comparable. I highly recommend you try it. It is not for everyone, but has some wonderful features.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Corel VideoStudio Express 2010 - cannot "see" h264 files ???
By andy15star in forum EditingReplies: 13Last Post: 6th Sep 2010, 15:29 -
Final Cut Express - Edited for 2 weeks in wrong "preset" how do I change it
By Chrushev in forum EditingReplies: 8Last Post: 12th Apr 2010, 04:08 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30
