Hi all,
I suppose that these things has been explained over and over again but I haven't been able to find an answer yet.
1st question:
Under Video tab: Encode mode
Under Advanced tab: Video source type
What I should use if I have divx encoded by somebody else (I don't know if it's interlaced or not) and I want to encode it to SVCD? Which one is usually used: interlaced or non-interlaced? (I don't know how these are different from each other ...) Are these two options the same thing (if I use non-interlaced in other I should be using it in other too ...)?
2nd question:
Under Advanced tab: Source aspect ratio
Should I use 1:1 (VGA) if my source doesn't have a standard resolution? (that divx is 512*217 or something like that) What should I use as a setting if I have for example PAL video and want to play it on my 16:9 TV ... [16:9 625 line (PAL)]? I have always used this 1:1 because I don't see the difference between these settings.
Does anyone know a webpage where these things are explained? 'TMPGEnc explained' in these webpages are not clearly enough explained =)
Thanks in advance!
Br,
-= EpiMann =-
If you are converting to a PAL format, then you can set it to non-interlaced.
If you set the source aspect ratio to 1:1, you are creating a 1:1 copy of the video aspect ratio. If the movie is anamorphic, then you will have a problem on a 4:3 TV set, as the image will be streched vertically. Because you are using a 16:9 TV, you should have no problems, cause your TV will strech the image back vertically, hence the aspect ratio will be correct.
The Dutchman
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
