We subscribe to a regular (not HDTV) Dish Network package, and I've been wondering if it would be possible to capture the video/audio streams digitally (on my PC), and if so what I'd need. I've already done some capture with analog TV tuner cards, but in the interest of quality, capturing the digital stream directly would be preferable. Do I just need a DVB-S capture card which I could hook up the coax cable from the satellite to, or is more equipment (and $) involved? Despite all my forum searching and Googling I'm still a little lost as to where the smart card goes.Sorry if this has been asked a million times before.
It cannot be done legally. In fact, I don't think it can be done illegally either. North American satellite services simply do not offer the ability for access cards (CAMs) to be used in a computer based system.
Not possible.
Capture it to a DVD recorder or computer capture card. Quality won't really be reduced.
Even if you could grab the satellite files, they are voodoo-like DVB files, they are not compatible with DVD-Video and they're hard as hell to edit because of how the DVB files can mix interlaced and progressive, as well as change framerates or even reverse interlaced, in the middle of a transmission. Multiple times, even!
DVB captures are largely a European luxury.Want my help? Ask here! (not via PM!)
If your DishTV box has a FireWire/1394 output, then you can connect it to either a DVD Recorder (100-150$) via the mini FireWire or iLink connection. You can also capture the stream to your PC should it already come equipped with such a connection, if it doesnt, then you can buy a FireWire/1394 PCI card for 20-30$. Im not sure what software you can use to capture it, but some 1394 cards come with basic editing/capture applications.
Since when do receivers come with Firewire output?
Guess I'll stick with analog capture for now. Thanks for the help.
I assume that most HD recievers have Firewire outputs. I actually work for a small cable company and we offer the DCT6200 as an HD box, which sports a firewire output.Originally Posted by lordsmurf
The normal digital cable box (DCT2000) has no firewire output.
What nonoitall might want to try, is to upgrade to a HD reciever box by Dish Network (assuming it has a firewire output) but set the component video output to 480p/480i. It may cost an additional 10$ (5$ for HD lineup + 5$ for box rental, but your probably already paying 5$ for the rental on the current SD box).
EDIT: Nevermine, the Dish Network only offers this VIP 211 as a HD receiver, which not only requires you to get your local HD channels over the air (no QAM tuning) but does not have a firewire output.
I just ordered a magicjack and was wondering if anyone else used one
By johns0 in forum Off topicReplies: 9Last Post: 4th Oct 2010, 02:46 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 04:53 -
left wondering ... which capture device ?
By hydra3333 in forum Capturing and VCRReplies: 4Last Post: 2nd Dec 2009, 03:23 -
i have this mp4 and i was just wondering....
By tryvora in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 23:04 -
Just wondering why h.264 support in mobilephones is a NO-NO in the US
By bacardi/avt in forum Portable VideoReplies: 10Last Post: 2nd Nov 2008, 14:58
