hi, i got a tutorial that teached me how to join all the m2v files and audio files in one single file, but i would like to know another thing: how can i join all the subtitles files to match my video track in maestro?
I think you need to provide some more information than that.
What kind of subtitle files do you want to join? What is the file extension?
And while you're at it: what is the "one single file" that you want to get?[/i] -
I have some srt files. I will convert then to the maestro format using subrip.
I have the following files (example):
Vid1 Vid2 Vid3
Aud1 Aud2 Aud3
Sub1 Sub2 Sub3
In the meastro timeline i added the videos in order, (Vid1-Vid2-Vid3) and did the same with the audio using audiosync function inside maestro (Aud1-Aud2-Aud3). But now i need to make a single file with all the subtitles, in order, to use with maestro in the same way. (while playing the Vid1 i get the sub1, Vid2 I get the sub2 and so on)
How do i Do that? -
If I understand you correct you want to create one subtitle file.
Try this: I always use Subtitle Workshop to joint *.srt-files. Go to Tools - Join subtitles... (or <CTRL> + J) and select the files you want. Depending on how the files are made you might want to check / uncheck "Recalculate time values" to assure that the three files come in sequence instead at the same time.
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
Joining Subtitles with Correct Time
By sambat in forum SubtitleReplies: 2Last Post: 9th Sep 2009, 15:43 -
Joining 2 Subtitles
By ashwin.terminator in forum SubtitleReplies: 2Last Post: 18th Apr 2009, 07:30 -
No Subtitles after joining 2 avi files
By kinghlg in forum SubtitleReplies: 10Last Post: 12th Mar 2009, 06:36 -
Problem joining subtitles with YAMB
By schmitt in forum SubtitleReplies: 0Last Post: 24th Oct 2008, 10:53
