I downloaded several svcd's. All play fine, but one, Dracula 2000, goes out of synch whenever I try to fast forward or rewind. Any idea what would cause this? If it is a problem with the mpeg itself, can I extract it and repair it?
Results 1 to 9 of 9
What probably happened is the people that made the svcd's could have used the old bbmpg which causes sync problems when ff/rw. I really don't know if you could fix this. there might be a softare program out there that might extract the audio and video but i doubt it but then again i could easily be wrong. Let's hope there is one because with out that i think there isn't much that you could do.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Surely one could de-mux (with TMPGEnc) and re-mux (with the better version of BBMPEG) the mpeg? -
yes aldus4 you are right...i have no idea what i was thinking, but then again it was 3 in the morning when i was answering that.
Don't worry. I think we all get that at one time or another - missing the obvious
By demux I am thinking you mean demultiplex? This is the option I see in tmpgenc. OR is bbmpeg better?
@choxie
What is better I don't know. It has however often been advised that you should de-mu(ltiple)x in TMPGEnc and
mu(ltiplex)x in BBMPEG. -
I play SVCDs that I make myself using DVD2AVI and TMPGEnc, they play fine in my Pioneer DV-535, ff/rw, pause, etc, and even in the software DVD player WinDVD v 3.0. The only problem is when I play them in Media Player, the audio gets out of sync.
I am very pleased with SVCD. -
In my cyberhome 212M, I've noticed that on (x)vcds, expecially those with many tracks, sometimes there are lipsynch problems.
I use to grabb videoclips from music channels, so there are almost 21 - 24 tracks on my (x)VCDs (plus photos, sometimes that goes to 35-40 "tracks"!). That problem use to happen between tracks 9-15...
I found a "solution" for this: When I see lypsynch, I pause the picture and then I play it. Then lipsynch is ok, for 4-5 tracks!
The pause works like a reset in my case...
Also, this problem happens only to non standard VCDs, like VCD with VBR mpeg 1.... Also I notice this problem with VBR SVCD...
No problem at all with CBR VCDs and SVCDs!
Maybe we miss something there...
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
