When i run DVDmaestro it says to me that if i want to use real time visualization i would need cinema codec or a hardware capable card. What would be a "mpeg capable card"? Something that encode mpeg at hardware level?
I asume they are talking about a capture card like a Hauppauge 150/350/500 that hardware encodes to MPEG-2: http://www.hauppauge.com/pages/products/data_pvr350.html
no -- they are taking about the card that came with DVDmaestro , which is a cinemaster card that doesnt work with winXP anyway.
It is for playback only - though all you need are the drivers ... It is covered in your manual and the drivers are found on your installation cd (but you have to extract them) or elsewhere."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i tought it was the the Hauppauge produts or something like that
, like those cryptograpy cards that generate the keys for you
edit: please help me to solve my another problem :P
https://forum.videohelp.com/viewtopic.php?t=304305
Hardware issues in encoding
By videobread in forum ComputerReplies: 3Last Post: 23rd Nov 2011, 09:38 -
Most Crytical Hardware for Encoding Video.
By Trktr51 in forum Video ConversionReplies: 2Last Post: 11th Aug 2010, 17:26 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Hardware Encoding
By jeby1980 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2010, 23:03 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52
