deleted
Ah, yes.. "Panic Room"..
Why not just disconnect the digital's cable out from the card, while
leaving the analog cable in. Then, proceed to record or whatever,
and see if you still suffer from this interference (or crossover) ??
I too suffer from similar noise. It would seem that my analog cable
is to blaim for most of my noisy captures. Because, whenever I run
my vcr (or connected dvd recorder's output) to my PC's, I get this
humming bar (video, not audio) that floats upward throughout the video.
But, when I record directly from the vcr or dvd recorder (w/out any
connections to my pc) the video is clean from interference.
Therefore, I think that the nearest conslusion of this interference is
something to do with the wire (Cable's) grounding outside, and is most
likely at the box. Anyways, that's my theory for both of us.
(you can either leave it, or lump it)
-vhelp 4029
............deleted
By elistian in forum DVB / IPTVReplies: 7Last Post: 20th Jul 2009, 00:48 -
Need to recover deleted files
By alegator in forum ComputerReplies: 5Last Post: 16th Apr 2008, 22:38 -
deleted....
By mjwhite in forum Latest Video NewsReplies: 1Last Post: 31st Dec 2007, 14:19
