I'm trying to convert a PAL encoded MPEG file, but TMPGenc tells me that I've got the evil floating decimal error when I first enter the file into the browser. So it won't even let me start to encode the file! I used the vdub freeze finding program, and it didn't find ANY bad frames!
Help, I've searched through TONS of posts, and the vdub solution was the best method I found.
Another question: Where can I find the pss.mcf file?
use vdub and do a direct stream copy then try the copy, if that doesn't fix it try pulling the audio off using vdub and use that as your audio source in tmpenc.
Any current ffmpeg builds floating to the top?
By Calidore in forum Video ConversionReplies: 0Last Post: 11th Jun 2011, 15:22 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 19:41 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22
