hello, i have just bought the sony dcr-hc26 video camera and was wondering what kind of program i need to put my videos to dvd. it came with a program but it looks pretty corny. these are the programs that i have nero 7, vso convertxtodvd,dvd shrink. i dont know if any of these would work. can you tell me what type firewire cord i should use to hook my camera up to the computer?
thanks alot for the help
ConvertXToDVD should be fine for easy conversion to DVD.
I use WinDV to transfer the DV from the camera to the computer, then VirtualDub Mod for editing and filtering, if needed. I usually save out the audio as a WAV file, then convert that to AC3 with ffmpeggui. I encode the DV video only to MPEG-2 with TMPGEnc encoder. Next I author to DVD format with TMPGEnc DVD Author, adding in the AC3 audio.
But try ConvertXToDVD first. The other method will give you better quality and more control, but you have to do a little more studying to get it all working for you. Either way, WinDV is one of the best for the transfers.
You will need a Firewire cable and a Firewire card in your computer. For the Firewire cable, the camera end is usually a mini Firewire 4 pin plug and the computer end is a regular 6 pin Firewire plug. Very common cable.
All these programs have guides available in our 'HOW TO' section and many are freeware. VirtualDub is a great DV editor and filter. You can also frameserve the output directly to your encoder, such as TMPGEnc and avoid making an in-between edited version to take up space on your hard drive. BTW, DV is about 13GB per hour, so have plenty of hard drive space available.
And welcome to our forums.
If you have the nero 7 package that is nero programs and nerovisionexpress you can do the trick.
You can capture via firewirecable from cam to computer provide you have a firewire card also of course.
Digital Camera question
By wingfan in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2010, 15:27 -
Question about way too high bit rate video from digital camera
By jimdagys in forum Video ConversionReplies: 12Last Post: 16th Dec 2009, 16:14 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57 -
Video Camera to Disc Question
By gomer in forum Newbie / General discussionsReplies: 7Last Post: 8th Nov 2007, 12:52 -
Digital Camera Question
By tenders in forum Off topicReplies: 57Last Post: 25th Jun 2007, 16:52
