What is a safe working temperature for a hard drive?
I recently installed the ‘Speed Fan’ utility and, in addition to reporting the CPU temp, I was surprised to find that it also reports my primary hard drive temp. I have no idea how/where it gets that info (therefore how accurate it is), but several times it got up to 95 degrees F (when the room temp was about 82 degrees)… is this temp OK? I have a second HD installed below the primary one and air circulation is limited due to the close spacing (no choice there). I removed the case side cover which helps a little, but I’m thinking a case fan might be better?
My HD's are both showing up around 39C, right after boot up, with alittle use they both go up to 46C. So you might need to add another Fan, just to be safe...
95F is not unusual for a hard drive, most run warmer than that on the surface. SATA drives usually run a little cooler. I've had a few drives hot enough to burn my fingers. They didn't last too long.
If you can install a case fan in front of your hard drive, it will help considerably. Many cases have a place to put one. I have one computer with 5 hard drives with about a 1/4" spacing between them and two fans in front of them, and all the hard drives stay below 90F. Makes a big difference.
EDIT: Bodyslide, I think those temps you show are in C (Centigrade)
39C=102F, 46C=114F
You may want to try one of these 2 fan removable bays if you are concerned about H/D temps, they fit in a standard drive bay:
http://www.newegg.com/Product/Product.asp?Item=N82E16817119502
I bought one a while back - noisy as hell and made no difference.
Regards,
Rob -
If you have room in your 5.25" drive bay, this configuration works nicely. And all of $10.
http://www.newegg.com/Product/Product.asp?Item=N82E16835150005
http://www.newegg.com/Product/Product.asp?Item=N82E16817991002 -
Thanks for the inputs. I guess as long as my HD stays below 100 degrees F, it should be OK. I'll check out case fans just to be sure.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
