Ok, so i converted 2 halves of a show to DVD using ConvertXtoDVD.
They joined, but the first half is VTS_01 and the second half is VTS_02.
How do i make sure they play together in DVD Lab Pro?
in convertxtodvd check the option sequential playback. burn the files convertxtodvd gave you and they will play consecutively. depending on your player there may be a slight pause changing vts.
if that really bothers you, re-number all the vobs from both sets sequentially, run vob2mpg on them to join into one mpg. import the joined mpg in dvdlab. demux. run the tool fix gop timecode on the mpv. author/burn.--
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 15:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 16:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 13:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
