I am trying to back up some of my programs. However, I cannot find the program disc to one of my programs. I have my product key#. How can I save the program to a cd-r so that when I reload it on my computer, all I need to add would be my product key?
If you mean copy the installed program to disc and use that to load to a different computer or back to the old one, you usually can't as the setup file is missing. You would need that from the disc to load the program back in properly. If you have the product key, you should be able to get a replacement program or disc from the manufacturer.
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 08:17 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
backing up computer
By vipertongn in forum ComputerReplies: 5Last Post: 26th Nov 2007, 12:08 -
'backing up' dvds
By nobbyiscool in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 20:25
