I am trying to burn .avi files onto a DVD.. however, when i do so, using Nero 7, the sound is off about 5 seconds of delay..
i have no idea why its doing this.. it works fine on my computer..
any help, would be appreciated..
thanks
If the amount of sync error is the same throughout the length of the video, you can add a audio offset + or - to the AVI before encoding, using VirtualDub. Or you can save out the audio as a WAV with VD and encode it to to AC3 with a program like ffmpeggui and combine it back with the video when authoring. Nero is not that great of encoder, you might try TMPGEnc or a freeware encoder like QuEnc.
Or try ConvertXToDVD if you want an easy method that will work with most AVI files. -
thanks.. i tried using ConvertXToDVD, however.. it said "error on frame ####", where #'s are numbers.. through the process. and it skips.. every 2-10 seconds.. but the sound is in sync otherwise..
ill try Quenc, thanks -
If you are getting errors, that could explain the sync problem. Missing or corrupted frames can do that. A software player may be able to ignore them, but not a encoder or a standalone player.
You might want to drop the AVI in VirtualDub Mod and 'Scan video stream for errors'. -
when i try to put the avi into the VirtualDub Mod.. it says the header is damaged and wont work.
dvdfab6 sound issues
By newbie77 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2009, 00:22 -
AutoGK sound issues
By SpaceMonkey52 in forum DVD RippingReplies: 7Last Post: 26th May 2008, 03:37 -
Sub/Burning Issues
By Ray_Casta in forum SubtitleReplies: 5Last Post: 25th Mar 2008, 10:50 -
burning issues
By burgkev in forum Authoring (DVD)Replies: 4Last Post: 3rd Mar 2008, 02:21 -
I am having sound issues with my computer?
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2007, 12:15
