I've just bought a DVD from Hong Kong. It's a ntsc video but maybe isn't a dvd but a video cd.
My problem is that my player can't read the disc and when i put it in it automatically ejects it after a while.
I'm running win XP pro, ATI Playcenter, power DVD.
Any suggestion?
sounds like you are beeing stopped by the region setting on your dvd/rom, there are firmware downloads to make most dvd/roms region free. You have to now the model number of your dvd/rom and then try and find them.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
