    Jul 2006
    New Zealand
    Recently got two DVDs from my uncle from my grandparents 50th and they are small enough to put into one DVD that is bigger. So I don't want to make the DVD itself smaller in size, just to fit the two small DVDs onto one bigger one.
    The main folder is VIDEO_TS one with VIDEO_TS and VTS_01_1 files in it. Do I need to change some code in one of the files and then get the files from one of the DVDs and put it in the other one, but of course rename the files so they go in order?
    If you need more details I'll be happy to give them.
    see https://forum.videohelp.com/viewtopic.php?t=284279
    you can't just put all files together.
