I am having a problem with trimming video clips and doing a 'Save As' step using MPEG Streamclip 1.7 for the Mac...Not sure how to correct this issue, but when I set the in and out points to trim down a smaller portion of a larger video clip, the first frame (which winds up being the poster frame which is used by most video browser apps as the thumbnail frame by which the clip is visually identified) winds up totally pixilated and funky...as soon as I play the clip, it appears properly, but the first frame is totally messed up! Can someone help me out and offer some suggestions that I can try to remedy this problem? Thanks!
Still happens when you place In Out points on next/previous key frame (up/down arrow)?
Mpeg Streamclip VOB -> MP4 frozen frame issue
By smmuck in forum Video ConversionReplies: 0Last Post: 16th Oct 2010, 19:16 -
MPEG Streamclip question: which is better? QT DV or Export to DV?
By Direwolf in forum MacReplies: 8Last Post: 29th Jan 2009, 12:38 -
MPEG Streamclip, Audio But No Video!
By EZ-Fan in forum Software PlayingReplies: 3Last Post: 23rd Dec 2008, 12:31 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38 -
How to convert video to iPod MP4 using MPEG StreamClip (free)
By Baldrick in forum User guidesReplies: 20Last Post: 6th Jun 2008, 23:48
