Hi!
neewbie question
i would like to change my divx movies into vcd or svcd
but i don't know how to put subtitles inside i have found o solution for dvd to vcd only what about divx is
maybe someone could help me pls?
my mail jap@wp.pl
regards
have you tried this?http://www.vcdhelp.com/srtsubsvirtual.htm
yes but my subtitles are in .txt files
so i probably have to convert to .srt or .ssa
but how? -
I subtitle anime and Godzilla movies as a hobby so I have some experience in this field
. Since you files are in txt format you have to convert them.
Now I know you are gonna hate me but you have to time your subtitles. The best way to do this is to extract the audio using Virtualdub and save it as a Wav file that SSA supports (I can't remember the specs right now) and time it from that. You will then have to copy and paste each line into SSA. Tedious yes, but that's really the easiest way I can think of.
_________________
Digital Kaiju Project
Information on Japanese Monster DVD's
http://www.godzillapalace.com/battra92
<font size=-1>[ This Message was edited by: Battra92 on 2002-01-07 08:03:16 ]</font>
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
