I have an .mpg file that that I want to frameserve using Avisynth (just a simple resize) and then I want to save it without having to re-encode the the whole .mpg. So far I can make a working .avs file that successfully frameserves my .mpg file in Windows Media player. I want to save this frameserved .mpg without re-encoding it. Please can somebody help.
The output from Avisynth is uncompressed and will need to be encoded by something. It is not possible to use AviSynth on a compressed source and not re-encode.
Buy My Books -
Hey thanks guys for your replies. I guess my question now is: Is there any way I could frameserve and re-encode my .mpg file WHILE retaining its quality AND size (+/- 10%)?? I tried to do this in TMPGEnc but it outputs a file that is three times the size!! I have tried lowering the bitrate in TMPGEnc but that severely worsened the quality of the output .mpg file (It is very important that size and quality of the output .mpg are approximately equal to the original .mpg file). Is this possible?? Please somebody help, I will pretty much try anything.
Hi,
Here's a link with 5 guides for frameserving:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
There's a HOW TO section on the left of the screen <------
https://www.videohelp.com/convert
Good luck.
EDIT - You still have to manage your bitrate to control the file size. Too large of a bitrate will put the filesize outside your desired range. TMPGENC allows you to strictly control your bitrate for your desired size.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have tried lowering the bitrate in TMPGEnc but that severely worsened the quality of the output .mpg file (It is very important that size and quality of the output .mpg are approximately equal to that of the original .mpg file). Is this possible?? Please somebody help, I will pretty much try anything.
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
ho to save?..
By im faster in forum Newbie / General discussionsReplies: 7Last Post: 7th Aug 2008, 06:16 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01
