What's the best way to convert video for a Pocket PC?
Erm... I've found loads of links and guides for creativng video for 'mobile' devices.
The problem is that just about every converted (by someone else) video I've seen is of VERY poor unwatchable quality!
I have a 400mhz pocket PC with a 2GB SD card.
I'm not worried about file size.
I can play normal xvid videos on it (normal being 700MB).
The only thing is... I think it struggles to cope on fast scenes.
I thought this might be solved by making the video be exactly correct for the pocket PC screen size.
AND keeping all other quality settings.
Is this a good idea?
Thanks.
OM
Ive been experementing myself, as I like the quality to be good. So far ive found that Windows media encoder, to be the best. but ive just downloaded cloandvdmobile, you get a 21 day trial, but it outputs in divx, so I put TCPMP onto my smartphone, again with some good results. but the audio isnt cd quality which i would prefer if i was using headphones. so back to the drawing board.
virtualdubmod works a treat for me.
i had a bit of trouble getting strted.
i needed keopi's xdiv.
but... now all is ok.
40+ minute videos encoded in 12 minutes.
playing looped video clip from pocket projector
By josefin in forum Portable VideoReplies: 1Last Post: 25th Jan 2011, 19:53 -
safe few bucks from my pocket
By mrdin2005 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Jul 2009, 05:26 -
Fujitsu Siemens Pocket LOOX
By mgowins in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 17:09 -
Movie player for Pocket PC??
By Cazz in forum Software PlayingReplies: 2Last Post: 2nd Jul 2009, 16:39 -
Is my Passport Pocket USB 2.0 dead?
By htp367 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 15:15
