Hi,
I wish to make a XML definition file to use with DVDAuthor in order to author audio + video, but I can't find examples
here is the XML I tried :
<dvdauthor dest="F:\TEST\DVD2\">
<vmgm />
<titleset>
<titles>
<video format="pal" />
<audio lang="en" />
<subpicture lang="pt" />
<pgc>
<pre>subtitle=64;</pre>
<vob file="F:\AA_ERRO\video.mpv" chapters="00:00:00" />
</pgc>
<pgc>
<vob file="F:\AA_ERRO\audio.ac3" />
</pgc>
</titles>
</titleset>
</dvdauthor>
But I get this error :
WARN: Skipping sector, waiting for first VOBU...
This error usually comes up if the source video is not 'dvdauthor' compatible.WARN: Skipping sector, waiting for first VOBU...
In this case it seems that you try to use elementary streams:
This is not possible! dvdauthor has no built-in multiplexer. Either use MuxMan, or multiplex your source mpv + ac3 with mplex (commandline) and use the resulting mpg file. Or use one of the dvdauthor GUIs (GUI for dvdauthor or dvdauthorgui) as there the script for multiplexing is generated automatically.<vob file="F:\AA_ERRO\video.mpv" chapters="00:00:00" />
<vob file="F:\AA_ERRO\audio.ac3" />GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 18:08 -
MKV XML chapter file creator
By perdigueiro in forum LinuxReplies: 3Last Post: 30th Jan 2012, 09:44 -
DVDAuthor XML subtitle pre command syntax
By Advocas in forum Authoring (DVD)Replies: 0Last Post: 29th Mar 2009, 13:51 -
FCP not recognizing a XML file
By lcquintana in forum MacReplies: 0Last Post: 17th Oct 2008, 13:54 -
GUI for DVDAuthor File format (.gfd files)
By tacman1123 in forum Authoring (DVD)Replies: 6Last Post: 6th Jun 2008, 17:45
