How do I resize video using VirtualDubMod?
I've used it before... but can't remember what I did!
VirtualDubMod is *powerful* BUT... very complex and confusing to use if new or haven't used for some time.
Thanks.
OM
sorry... i meant to say video frame size (i think).
for example... the video is 720 x 570.
i want to resize to 320 x 240.
i can't see the option to do this.
i know it's there!
AND... i don't want to recode the video.
my pocket pc is fast enough to play the normal files anyway.
the only reason why i want to resize is to overcome the fact that it stmbles on fast scenes.
thanks. -
Under Video->Filters add the resize filter.
and you must reconvert the video if you resize. -
when u say reconvert... are there any optimal settings i should use?
thanks. -
That is entirely up to you....but if you are looking to upload to something like YouTube you'll definately need more than just resizing.
I also use the 2:1 reduction (high quality) filter more often than the resizing filter.
How to resize an online video
By Maylon_Brando in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2012, 05:58 -
Resize video without converting
By JOHNINA in forum Video ConversionReplies: 6Last Post: 27th Feb 2010, 21:25 -
Resize filter in VirtualDubMod
By CSULB71 in forum Video ConversionReplies: 5Last Post: 28th Dec 2008, 11:48 -
can I resize using virtualdubmod
By thecrock in forum Newbie / General discussionsReplies: 5Last Post: 22nd Oct 2008, 16:54 -
crop video using virtualdubmod
By mridang_agarwal in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2007, 10:04
