Hi folks,
Does anyone know how to change the default paper size for the R220? Everytime I print something it automatically defaults to A4. I have to manually change it to letter. I don't mind making a manual change if I use legal paper but it is really p***ing me off to have to make the switch to letter everytime.
Thanks for helping
All's well that burns well.
Folks, I have the same problem. Changing the default form size does not work from control panel.
Changing paper size under Printing Preferences on the Properties page works for me on the R200.
Hmm, maybe is the software version.
I will download the latest R220 drivers and after instaloing them I wil try one more time.
Some applications use their own printer preferences. So check the app if you haven't already.
Yes, for instance if you create a Word document with paper type of 8.5 x 14 then save it, each time you load it the printer output will be set to 8.5 x 14, regardless of printer settings. The fix for this is to set the paper type in Word to 8.5 x 11, SAVE the document, then it will request 8.5 x 11 from the printer.
Many other progs have a similar feature. -
Lates drivers did not fixed my problem.
This is wwhat I´ve been doing. Thanks for the help.Originally Posted by Nelson37
DVD cover size and paper
By Digiface in forum MediaReplies: 26Last Post: 14th Oct 2011, 08:41 -
HELP changing default settings in Vegas
By TKB in forum Newbie / General discussionsReplies: 0Last Post: 16th Jun 2011, 00:04 -
Changing default video renderer
By deadgamer in forum Software PlayingReplies: 0Last Post: 3rd Jul 2010, 07:02 -
Changing DeVeDe default settings
By henrik.uggla in forum LinuxReplies: 0Last Post: 25th Jun 2007, 13:29 -
Changing Vegas' Default Media Library Location
By ShBm in forum EditingReplies: 0Last Post: 9th Jun 2007, 13:22
