When trying to convert from Divx.avi to SVCD I cannot get any output when using 2pas VBR put it's ok when using CBR. Why is this.
It appears to be encoding ok, but there is no Mpeg in the save folder when it's done or when I stop it to check the quality.????
when encoding 2pass will the encoder first check the source the first pass too calculate the bitrate thats why there are no mpg file but after 50% of the progress it starts the second pass and generates the mpg file.
Thanks Baldrick.
It it worth converting Divx to svcd or should I stick to vcd? -
If the Divx quality is very good it will and it will be a big loss in quality to convert to VCD, i go vith SVCD since it can give much better picture.
just my 2.
Well, I am the slime from your video.
Oozin' along on your livin'room floor.
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 14:47 -
x264 for Blu_ray: 2pass or crf?
By wiseant in forum Video ConversionReplies: 3Last Post: 2nd Jan 2012, 15:12 -
FFMPEG MPEG-2 VBR output size not coming out as expected
By DJRumpy in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 09:19 -
X264:How do you encode in 2pass ?
By themaster1 in forum Video ConversionReplies: 9Last Post: 25th Apr 2009, 17:29 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55
