Hi All,
I've mpv and mp2 generated from avi. mpv was 23.97fps and authoring program didn't processed it and offered me pulldown, i've accepted and got 25fps mpv, but now it's out of sync with original mp2. Help
You would have to give us a little more info. You have MPV and MP2. What program did you use to get that? What's the original format? PAL? A Gspot screen shot would help. You can blank out the title if you like.
If you are converting from PAL to NTSC, there's lots of room for problems.
Sync is one of them. Start over and give us the whole story.
I've use dvd2svcd with cce 2.5, original was avi. I've several avi's, after encoding them with dvd2svcd cce 2.5 pair to vcd's i get mpv's and mp2's respectively and then authoring them with DVD lab pro and burning several movies to one dvd media. So some mpv are pal some ntsc. The files were ok befor i run the pulldown offered by DVD lab pro. I've have file on different computer so i can't post Gspot screens right now but i will if you still need them. The mpv's lost time code also after pull down. So i see that converting mpv's from 23.97fps to 25fps made them out of sync ,but don't know how to cure it.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
