Results 1 to 12 of 12
  1. All my textual data from the last 10 years, is just 70 Megabytes.
    A non indexing application can search that in just over 4 seconds.
    The net search Co's have trotted out their indexed searches
    which are complex database monstrosities designed for millions
    of times, that amount of data.
    A lifetimes reading, can fit on a DVD (4.7 Gig)
    It would be silly, to archive and search info, you have never read.
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I don't understand your point, it may be unusable to you but for others it's a huge timesaver. Let's say you can gain access to the database here which is nearly 2GB's, you now have in you possesion one of the largest single archives pertaining to digital video available. Without indexing your search time is now approaching 2 minutes.
  3. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Indexing makes a lot of sense. You don't have to have read something for it be useful.
    Meta Data is a good example.
  4. Originally Posted by thecoalman
    Not quite 2 minutes. If there are multiple matches, some will be displayed immediately.
    And they will be in context. Yours won't. It's ALWAYS the context that you search for.
    The 2GB example is data you would probably want to search then read, search then read.
    Put that 2GB file on a DVD along with a good Desktop Search and you are portable. I don't
    think indexed search can run from a DVD?
  5. Originally Posted by Faustus
    Oh, I can see where I wouldn't mind a peek at the coal man's 2GB file, indexed or not.
    Meta Data does have to be pulled from the file.
    My preference, is not to bury the text in non text files.
    All my meta data is in simple text files that accompany the
    picture or video files.
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    That would create like a thousand little files. Indexing is better.
  7. Originally Posted by Faustus
    Nope, just 1 text file for the 5000+ family album pictures.
    1 line describing the picture and 1 line with the path.
    Don't force people to put textual info into pictures, music & video files
    I don't want to know how to do that.
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    :P http://www.friedemann-schmidt.com/software/exifer/
    Features
    Supports EXIF (up to 2.2) and IPTC data in JPEG and TIFF files
    Reading and displaying of makernotes by Canon, Casio, Fuji, Minolta, Nikon and Olympus
    Backing up, restoring and comparing metadata (EXIF/IPTC)
    Editing of metadata (for JPEG files only)
    Inserting EXIF data from THM files (for JPEG files only)
    Creating/inserting/rotating EXIF thumbnails (for JPEG files only)
    Customizeable view of metadata
    Export/import of metadata (CSV, Canto Cumulus, descript.ion files)
    Renaming and redating with various formats
    Lossless rotation (for JPEG files only)
    Cropping (with aspect ratio)
    Watermarks
    Slideshow
  9. Originally Posted by thecoalman
    Features
    Watermarks
    Slideshow
    I said I didn't want to know that.
    What percent of percent of existing jpg's would be encoded?
    1/2 of a percent maybe. Wouldn't that limit people from shooting
    and shooting pictures. When they have to encode and encode?
    My excuse is the family album was done 6 years ago. I only
    learned how to encode. Just now.
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Do you mean which ones would have exif data? Depends on the device they were made with and that any software that touched them supports maintian ing the data but every digital camera would have this information stored now. Right down to whether the flash fired or not.
  11. Originally Posted by thecoalman
    I should extract the exif data, when cataloging JPEG files.
    I use the meta data when cataloging mp3 music files.
    Maybe I have been too focused on digital video.
    on another topic. Do you ever find neet stuff in the coal?
    I found dinosaur skin imprints a couple years back.
  12. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    In the coal itself no, I only get to see the processed product.... At most you might see some flecks of "fools gold". I'm no scientist but anthracite is so dense I'd assume any remnants have been obliterated. It's not like soft coal that breaks easy. It has more a consistency of glass. In the rock surrounding the coal they frequently find fossils, ferns especially.
