How would I go about reducing the bitrate of an AC3 to a lower bitrate AC3 file?
Results 1 to 9 of 9
"The secret of genius is to carry the spirit of the child into old age,
which means never losing your enthusiasm."
- Aldous Huxley -
What program are you using to convert to AC3? If you are looking for more space for video encoding bitrate for a DVD, you won't get a lot of gain by reducing the AC3 bitrate.
Yes, it's normal. Personally, I don't think it's too bright to lower the bitrate of a 192 AC3. There are other better ways to reduce the size of a DVDR by a little bit. One might be to use DVD Shrink. Another might be to reencode just the credits (opening or end) for a lower bitrate and stick them back into the DVD. A third might be to still a menu or 2 if you have motion menus. Depends on what you know how to do.
How would I reenocd just the credits (opening or end) for a lower bitrate and stick them back into the DVD?
- Aldous Huxley -
Demux the cell containing the credits using PGCDemux. Reencode them for a smaller size, author the credits and stick them back into the DVD using VobBlanker.
This assumes that the end credits are long enough that they can be shrunk down without completely detroying them. Depends on how much you have to shave off the DVDR, and how big they are to begin with.
You could always cut them out, or a part of them out, using the cutting part of VobBlanker. I wouldn't do that, but some people don't mind losing a part of the movie. -
Doesn't seem like I can reencode the opening and ending as it run together with part of the movie. There are 6 cells and each one is about 20 minutes in length. I will probably run it through DVD Shrink with 98.5% compression.
- Aldous Huxley
ripbot-made mp4's ... reducing bitrate
By zero7404 in forum Video ConversionReplies: 4Last Post: 22nd Nov 2011, 18:41 -
AC3 vs. MP3 at the same bitrate
By wallywalters in forum Video ConversionReplies: 5Last Post: 11th Feb 2011, 10:21 -
trying to edit ac3 bitrate of mkv
By dgizzy in forum Newbie / General discussionsReplies: 8Last Post: 11th Dec 2008, 14:14 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11 -
Reducing bit rate of AC3 file of DVDs
By rock_king_my in forum AudioReplies: 9Last Post: 7th Dec 2007, 05:33
