I know i posted a similar post don't report because the topic moved away from the original topic and no long fits the topic
For 300 i can get a
JVC SR-MV30U
with one button dubbing although it is a combo unit
or i could get a
jVC HRS-9911 for 250 and a recorder for about 300
the second option couldn't be 300 better could it?
This will mostly will be used to COnvert VHS to DVD-RW to be imported authored and burned from a computer.
Thanks for the reply.
I have looked around but i couldn't find quality results compared... has anyone had experience with either setup
Then I see no reason to get a DVD recorder. You will not get optimal quality. Get an ADVC 110 from Canopus. http://www.canopus.com/products/ADVC110/index.php. Somewhere around $200.Originally Posted by SquashkyTerje A. Bergesen
i need to convert many tapes so i feel recorders are quicker for my purposes thanks thouhg
I was thinking JVC HRS 9911------>monster cables-----> JVC-DV-m100s burn to DVD -rw and then use a comp from there
is that worth it for vhs conversions or is a combo better ?
all for about 450 -
DV compression is not better than a good DVD recorder, especially not one based off LSI technology (like JVC).
Honestly, I'd try the JVC SR-MV30U
Of course, that means it'll only be good for straight transfers of unprotected tapes that need no advanced restoration (such as proc amp work, detailer work, etc).Want my help? Ask here! (not via PM!)
wow really wat makes you say that????? every thing i have read says that you say never a combo??? what makes the change?
Is there a quality difference? -
Build quality on the professional equipment is often better.
This is an exception to the "avoid combo" rule that is often not mentioned, mostly because combo pro equipment is rather obscure.
I considered one of these myself (actually, I think it was another model, but close enough), researched them a bit, but the need for it never happened.Want my help? Ask here! (not via PM!)
Quality aside I still wouldn't consider a combo unit. My thoughts have always been what if one breaks... not a great anology but let's say you buy a TV/VCR combo and the TV goes... you now have the largest VCR on the planet. :P
the combo setup says this on its web site
Post-Processor also applies several noise-reduction technologies including Block Noise Reduction Circuit to reduce MPEG block noise, Color DigiPure for 3D noise reduction with enhanced color and details, and Hadamard Noise Reduction to eliminate mosquito noise in virtually any DVD.
is that apply ed to the final DVD or is that only used when the DVD is played though the DVD player. So does that help the final quality or is it only temporary?
Setup default dvd player
By bambam in forum Software PlayingReplies: 15Last Post: 26th Jul 2014, 21:07 -
VDub setup for VHS Capture
By HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 04:48 -
Room for improvement in my capture setup? (VHS)
By Killer3737 in forum Capturing and VCRReplies: 2Last Post: 4th Oct 2009, 16:55 -
Beta/VHS Video Restoring tools. Is this a proper setup?
By HOTPROPHET in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 01:48 -
DVD / TV / MKV setup!
By danielbanks in forum DVD RippingReplies: 4Last Post: 10th Aug 2007, 04:35
