Hi,
Working with some muxed PAL MPEG2 files that I want to convert to NTSC streams for DVD Studio Pro. Not sure what the best way to go about this is. The files are 740 x 404 which I understand to be the right size for PAL 16:9 files. More info about the files can be found here
http://tinyurl.com/lth9t
I've tried a couple of different settings on ffmpegx but I keep getting the a square file and not a 16:9 file (and always muxed). There's also a 6px black border on the right and left that I would like to crop out during the conversion. Any help or pointers in the right direction would be great. I'm not opposed to reading so links are good too. I've seen a few threads here but mostly going from NTSC to PAL.
Thanks,
Jack
Thanks for the response. I think I have it solved on my end. I just have one final question. There's a bit of a stutter in the NTSC file. I'm guessing that's beacause of the frame rate difference. Is there a way to fix that or am I just going to have to live with it?
Thanks,
Jack
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
