Hello All. Apologies for cross-posting. I have some movies that are HR xvid (960 x 528) with 5.1 AC3 audio. I want to convert them to play on my philips 642 - if I try now it says resolution not supported. I have FFMPEG and D-Vision to work with (I'm using a Mac), but so far all my attempts wont play on the Philips (they look/sound fine on the computer). Can anyone provide detailed settings for either app that would work?
Many Thanks,
DP
Try reencoding them to dvd specs. 720x480 for ntsc.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You can keep them as avi but you need to reencode them to a resolution your dvd player will accept. It will accept 720x480.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Can't play Xvid on my Philips DVP5982
By rreeze in forum Newbie / General discussionsReplies: 10Last Post: 20th May 2008, 10:53 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
