I use shrink and decrypter to backup my dvds. This is no problem, I can play these in my dvd player no problem.
I have a set of dvd files (tv shows) I've downloaded, and load into shrink - it analyzes the folder like a normal dvd, i then hit the Backup button to back up the movie with shink and burn with decrypter. The final dvd won't play in my standalone like ALL my 1:1 copies I've made using the EXACT same method. However, when i put the disc in my PC after burning, it loads with media player classic like a normal dvd, menus work, etc.
So, why doesnt' this work? thanks
Bad disc?
Try a different brand.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
What brand of Media are you using? Also which DVD player is it the Apex 500 in your profile? Are the TV shows PAL? maybe the Apex Doesn't play PAL files.
Here's a link to what the Apex will and will not play.
https://www.videohelp.com/dvdplayers.php?DVDnameid=18&Search=Search -
This player is the culprit: http://www.symphonic.us/products/dvd/wf104.html
things to mention:
1. like I said, my 1:1 copies work perfectly, the media is not at fault here, the downloaded files are (supposedly) the cause of my problems.
2. having said that, it must be PAL compatibility issues like Bodyslide pointed out. How can I convert to NTSC and then burn to a compatible format? thanks.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
DVDFab -- DL burns don't work in standalone
By eclipse95 in forum DVD RippingReplies: 9Last Post: 19th Feb 2008, 17:48 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35 -
subpictures work on powerdvd but not standalone player
By domhnall in forum DVD RippingReplies: 6Last Post: 19th Aug 2007, 08:12
