  1. Member Crazyj32's Avatar
    Apr 2006
    Is there a program out there that will convert a pal dvd to ntsc automaticly and with good results?
    USA
    No, not really. But here are a few methods and guides: https://www.videohelp.com/convert#4;41
    The DGPulldown method is probably the easiest, but not always compatible with all players. PAL>NTSC conversion can be a fairly complex operation to get good results. Especially if you want to keep everything on the DVD, including menus, etc.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    There are some region free dvd players that can play pal in the ntsc region.
    Another option is to get a hacked xbox and play it back and capture it onto a dvd recorder or your capture card. A few downsides though - no 5.1, no menus, and its a realtime dub. But you don't have to do hours of converting, its just the lenght of the video. Then you can author your own menus.
  4. Member Crazyj32's Avatar
    Apr 2006
    ok. thanks for the replies.
