Hi
I just have question How can I PUT Avi or Divx ovie file on DVD besides converting to DVD format
Thanks in advance
Buy a divx compatible dvd player and simply burn it as an avi file onto the dvdr. Then you'll be able to play it on the divx compatible dvd player without converting.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
How do I know or how can I find out that my current DVD player support divx compatible ?Originally Posted by yoda313
You would likely know if it's Divx compatible. Few US players are.
For a list of Divx compatible players: http://www.divx.com/products/products.php
As an alternative, with some quality loss, you might look into a program like ConvertXToDVD. It can convert most AVIs, (Divx and Xvid and others) to a DVD player compatible format. It does take a while, and there are better methods if you want the highest quality, but the program is easy to use. There is also a freeware version still available with a few less features; DivXToDVD.
Or check the guides to the left and search for Divx to DVD conversions in 'CONVERT'. <<<<<<
If you are also converting PAL Divx to DVD, it gets a little more complicated.
How would your know???? You are really kidding right???
They would play!! Then you would know.
Serously man,,, The player specs will tell you. Just do a search for Divx DVD player and you will get lots of hits on Google. I sitll have my old Phillips 642 or whatever the # is and I use it once in a while to look at AVIs from tutorials. I assume you are looking at viewing moview?? Yeah, they will not look as good as the real original DVD but I assume you know that right?No DVD can withstand the power of DVDShrink along with AnyDVD!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
DVD to avi/DivX
By nempo in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 21:47 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 17:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 14:20 -
Which is best app for DVD to DivX or AVI....?
By snadge in forum Newbie / General discussionsReplies: 26Last Post: 1st Feb 2008, 11:14
