I am trying to join clips of audio to make one audio file, but I wanted to know what program would be best for that. Im trying to use audacity, but im having a hard time figuring out how to join the clips so that you dont hear any pop or shift in the audio when it goes to the next clip.
What Im doing is taking a short audio clip and copying it, then pasting it over and over ontot he end of the previous clip in order to make the audio longer. Im just wanting it to loop over and over so that its 3 minutes long instead of 30 seconds. is there an easier way of doing this so that the transition to the next clip is seamless? Ive been using audacity and i just cant get a smooth transition, its like its just off by a couple beats. If anyone could give me some tips, that would be be great. Thanks
You can butt it up next to the end of the first clip. Just highlight and erase any empty space. You can simply copy and paste it over and over again as many times as you want.
If you want a smoother transition you can do a fade in/out.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
well i did try cutting off the empty space, but i can still hear an audible click when it moves to the next clip.
when i said transition, i meant something that would blend the end of the first clip with the begining of the next clip. -
You should be able to mix the sounds by selecting the end of the first sound and chosing "mix from this point/start marker". I havent used it in a while, so I'm a little rusty.
Maybe even try something like this?
http://www.agnula.org/documentation/dp_tutorials/audacity/
Multiple clips form a single video file
By ripper316 in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2011, 13:52 -
Joining clips - lost footage or audio off track
By imrealdumb in forum EditingReplies: 2Last Post: 27th Jun 2009, 18:58 -
"Seamless" vob joining results in multiple audio tracks
By grannyGeek in forum Authoring (DVD)Replies: 2Last Post: 3rd Mar 2009, 04:29 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 15:55 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05
