    Jan 2005
    is this possible? and if so what program is suitable for it? thanks a lot in advance
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    virutaldub. File - save wav.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Does it still do that? I thought that you had to select the audio stream, then save to wave.
    Either way, virtualdub is correct.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    I think you're thinking of virtualdubmod. The standard virtualdub should still do the file-save wav feature.
    Jan 2006
    Australia
    deleted
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    For another alternative, there's also AVI2WAV. It's what I've used in the past, though some have reported it may have problems with AC3 audio. I don't know if that's true, though.
    Others on these forums have also suggested Goldwave.
    Dec 2004
    Australia
    Extracting to me means demuxing, not decoding though. AVI-Mux GUI or VirtualDubMod are good for this.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    BeSweet can do this, especially if you want to transcode it (use the Wizard at least to begin with). Input: AVI, output WAV, MP3, MP2 etc. But note the AC3 export is a bit flaky, usually too quiet.
