What should i be looking for in Gspot, to make sure that the current avi will work in my Phillips DVP-642 divx player, I understand Qpel/GMC but sometimes i may put in my divx/xvid and it will not have audio, or the audio works but the video is funny coloured and blocky.
Funny coloured video would be due to the use of CQM's. You would need MPEG4Modifier to check for that. Also reports qpel/GMC. You should also check the resolution as anything higher than 720x576 won't play. Infact I believe some people don't recommend higher than 640x??? for the 642.
As for the audio. Could be an unsupported format, sample rate, etc.
What parameter in Gspot or MediaInfo shows if AVI will play in DVD player?
By jimdagys in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 02:58 -
VirtualDub can't find an audio compressor while GSpot can for my avi. Help!
By yosarian in forum AudioReplies: 13Last Post: 2nd Dec 2008, 09:01 -
Steps to ensure best video shoot
By bowmah in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2008, 23:17 -
What program will ensure a DVD will play all the way through?
By kozara in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 15:33 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
