A few years ago, my sister paid to convert some of her VHSc videos to VCDs. I asked her to send me the VCDs recently. My sister somehow sent me instead a DVDR with 7 subdirectory of 7 VCD data to save money and postage. She did not know that she had to convert (it would have overwhelmed her if she had to do it) it to MPEGII before copy to the DVD+R. What can I do to save these VCD videos?
Results 1 to 15 of 15
Sam Ontario
make new vcds? then copy the .dat files from the vcds and author new with vcdeasy.
make a new dvd-video? then add the .dat files from the vcds in tmpgenc dvd author. -
just a tip: if you're going to DVD-video, when encoding, set the bitrate higher than if you were going straight from say..DV tape to DVD.
VCDs already max the crap out of MPEG-1, so they already have a decent amount of macroblocking on the video (especially if its coming from a VHS source)...converting to MPEG-2 will increase it even more if the bitrate is average for a clean source. -
After extracting MPEG video from the DAT files don't convert it to MPEG 2. The 352x240 MPEG 1 video is perfectly legal for DVD. Just convert the audio to DVD specs.
You can demultiplex the DAT files to M1V (video) and MP2 (audio) files with the free version of TMPGEnc (File -> MPEG Tools -> Simple Demultiplex) -
SVCD2DVDMPG can reencode demux and reencode audio to fit DVD specs and it's freeware
On the version I have (3.55, GUI version), it's under the VCDGear category (press the 'vcdgear' button on the top row), then select "dat - > mpeg" from the 'Extraction / Conversion' dropdown. You should then be able to select .dat files with the file box below.Originally Posted by Sam OntarioIf cameras add ten pounds, why would people want to eat them?
It said 'Could Not Locate MPEG stream' when I loaded MUSIC03.dat which has the main chumk of the 1st VCD video. Is it corrupted by burning VCD data directly to a DVDR?Originally Posted by Ai HaibaraSam Ontario
Zosma to the Rescue
By wulf109 in forum ComputerReplies: 0Last Post: 16th Oct 2011, 09:59 -
Rescue JVC DR-MH20SE harddisk
By Anamon in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Aug 2010, 17:29 -
Rescue WAV audio file
By Richard_G in forum AudioReplies: 8Last Post: 24th Sep 2008, 20:27 -
How can I rescue video from a DVD?
By OM2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2008, 14:46 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 04:24
