I tried using Subtitle Workshop .. which is perfect for editing all formats (.SRT, etc.) but while adding time delay to *.SUB file, for some reason unknown, the subtitle file goes haywire..
So, is there a separate app for correcting *.SUB files?
Sure something can be done. I'm sure there's a better way, but since I'm used to working with SSA subs, I'd first convert to SSA, and then open them in SubStation Alpha. Up at the top, go Timing->Shift Times and Save. If for some reason they have to be in SUB format, then convert back.
dvd m2v time delay problem
By codemaster in forum DVD RippingReplies: 14Last Post: 28th Nov 2010, 20:02 -
where is the audio delay time stored on an authored dvd?
By Toastie in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2009, 07:45 -
DTS audio time not correct
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2009, 10:31 -
Time Delay Record
By danieldunn10 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 22nd Apr 2008, 13:11 -
How to set delay time of all text in the sub.
By hmanhha in forum SubtitleReplies: 3Last Post: 22nd Feb 2008, 13:53
