  1. I use the vcdhelp bitrate calc when making SVCD.
    I use LSX plugin and burn the MPEG with Nero 5.5
    But here is my question when I want to put 60 min on a 74 min CD. The vcdhelp bitrate calc says I shold set the video bitrate to 1444 I always use 224 in audio bitrate.
    But I get a file that is to big for a 80 min CD.
    Even if i set the bitrate to 1300 I can almost not even fit it on a 80 min CD.
    I have only used CBR for this.
    Is there something wron with the caltulator????
    BUT howcome when i want to burn 52 min on a 80 min CD, the bitrate chosed by VCD calc is correct?..
    xabat
  2. Just checked the calculator, somethings wrong. With a video bitrate = 1444kbit/s and audio=224kbit/s for a 60min source you should get a 750.6MB file. That's slightly larger than the 740MB limit.
    First, I'd recommend lower the audio to 128kbit/s to give more bitrate to the video (but that's me ).
    To generate a 735MB file for a 60min source you have 1633kbit/s total. So thats:
    Video = 1409 & audio = 224 OR
    Video = 1505 & audio = 128
    <font size=-1>[ This Message was edited by: Vejita-sama on 2002-01-07 03:13:23 ]</font>
    I get it to 733 MB so it would fit...it is 750 600 kB.
