Hello all,
I have DV footage that I will be using with virtual dub in order to use the delogo filter. Just wondering, after I have applied to filter, what format should i output??? Should I just use uncompressed AVI, or should i download a DV encoder.
Thanks!
Results 1 to 11 of 11
That would depend on what your destination is. What is your end goal?
Buy My Books -
Read this link and ask there. As Clinton would say "I feel your pain". Unlike Clinton, I'm seeking a solution. So far it is one decompress generation down to use Vdub filters.
https://forum.videohelp.com/viewtopic.php?p=1541447#1541447 -
Well my final output would be MPEG-2 (to be burned to DVD).
An idea popped into my head but i'm not sure if it will work. Seeing as I'm using Sony Vegas to edit my work, would a program like WAX 2.0, that integrates into Vegas and allows the use of Vdub filters do the job (without needing to recompress)? -
I'm all ears.
http://www.kiva.org/about -
hrmm...thanks for that reply. I'm at work now, but I will be trying that as soon as i get home (and will post my results). Thanks!
Nope, couldn't get the Delogo filter 1.3.2 for virtual dub working with the combination of Wax (2.0e) and Sony Vegas (6.0c). I go through the configuration options, but the video is left untouched by the filter once finished with the configurations (works in vdub). Has anyone been able to get this to work in Vegas???
Originally Posted by tarrickb
The other option would be to install the DebugMode Frameserver, use Wax as a standalone app, and then frameserve from Wax into Vegas."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
How to get 10 hrs SD footage onto BD?
By ruffhouse in forum Authoring (Blu-ray)Replies: 52Last Post: 16th Nov 2011, 13:25 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 14:24 -
Footage Download
By josel in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 16:54 -
Noise on dv footage
By cd090580 in forum RestorationReplies: 3Last Post: 3rd Nov 2007, 19:08 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 04:54
