i have followed the tutorial given at the top of this forum using those tools. i got sustitles of divx website however the subs do not match to what is being spoken how do i arrange ot so they match up. and how would i make sure this dosnt happen again. also is there a way to watch avi files witjout having to permanantly putting subs on them? thanks for any help.
PLEASE wait a few days before you bump/reply to your topic.
use vobsub / vsfilter and you can play avi with switchable subs, www.videohelp.com/play#subs . you can also change sync times directly in vobsub.
or sync manually with for example subtitle workshop, open the avi and the sub.
or just buy movies/TVseries with subs and you wont have any sub problems.
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 17:45 -
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 15:58 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
How is .SUB timing calculated ?
By darconio in forum SubtitleReplies: 5Last Post: 12th Dec 2008, 08:26 -
ccextractor timing issues
By Neisse in forum SubtitleReplies: 23Last Post: 16th May 2008, 09:23
