Hello there,
I haven't posted here in a while, nice to see it still looks familiar. Any way my question is: do you know of a way to force autogk use a certain xvid profile like advanced simple @ L5 when it encodes? I typically use gordianknot and set the profile selection manually for divx/xvid standalone player compatibility, but it would be nice to be able to use autogk for ease of use.
I've tried adjusting the xvid profile levels directly and setting the xvid encoder settings, but autogk doesn't seem to adhere to them. Is there some autogk settings file where this can be altered or something? Any help would be appreciated
hmm that's too bad if that's true and thanks for taking the time to respond. If anyone knows any different please feel free to respond. Meanwhile I'll just continue using regular gordianknot I guess.
celtic_druid is correct.
Both the AutoGK ESS and MTK options are designed for standalone compatability, perhaps the ESS option a bit more.
No. Are you claiming that using AutoGK with the ESS chipset option enabled makes XviDs somehow not compatible with your, or any other, DVD/MPEG-4 player? -
actually thanks to celtic druids post I looked it up and found the hidden options menu (something I didn't know existed cause I never felt the need to look up guides/manuals for autogk). The standalone compatibility option was turned off on mine, so I will have to play around with it.
Thanks for the help. -
Oh, so you didn't install it right in the first place? Then reinstall and enable the option. That'll be better than changing it every time in the Hidden Options.
Thanks for the suggestion (in my rather slight defense the standalone option is unchecked by default during installation. Not a good excuse, but I didn't even have a standalone when I first installed it, let alone worry about ess vs mtk based standalones). So I did that now and having tested ess versus mtk, will definitely be going with ess. Thanks for all the help guys. A little , but hey I learned something new.
*sigh* Another issue - "force mono" missing in AutoGK.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 15th Apr 2013, 20:32 -
AutoGk -- how to "force" fixed resolution ?
By ralf07 in forum Video ConversionReplies: 6Last Post: 10th Sep 2011, 17:21 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 15:37 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
Force AutoGK to 16:9 after adding pixels to autocrop?
By nerdgeek in forum Video ConversionReplies: 8Last Post: 30th Sep 2007, 13:14
