I haven't run out of 8X discs yet, so I was a leetle bothered to read a post on another forum about 8X discs disappearing from the market and 16X discs not working right in the Lite-On 5005
http://ccgi.mgillespie.plus.com/liteon/smf/index.php?topic=3708.msg39069
Anybody else here having 16X media speed problems on older machines?
They should all be backwards compatible.
If you're having any problem do you have the latest firmware for your drive??
Also depending on your peronal budgets new 16x dual layer burners are going for as little as $35 on websites like newegg and tigerdirect. So upgrading is not as painful as it used to be
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have the LiteOn 5005 which I reverted to older firmware (to retain certain functions), and I have had no problems burning Verbatim 16x DVD+Rs. *I have not tried 16x DVD-Rs though, so I don't know if they cause any problems.
Thanks guys! just fyi- I called HP (discs I've been happy with) and got right thru to India in record time
They are so big they don't even know they sell blank media. After a while I got the answer that 8X media are history, so if you do need'em & find'em, better buy'em now.
Don't seem to be getting anywhere. How to connect pc to dvd recorders
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 22:26 -
Why Don't Double Layer Discs Work?
By GordRocks in forum MediaReplies: 14Last Post: 10th Feb 2010, 09:16 -
Should I burn 16x discs at 8x?
By sky captain in forum Authoring (DVD)Replies: 22Last Post: 19th Dec 2007, 22:58 -
Samsung DVD-HR737 doesnt work with 1-16X DVDs
By bengt39 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Dec 2007, 12:27 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22
