    Jul 2006
    Austria
    hi
    im trying to capture a console game over my tvcard with virtual dub
    i have a pinnacle pctv rave
    the game is a jap game and im playing it on my pal gamecube with a freeloader
    but when it shows the game on the screen the picture is 1/3 over the top and is comig out from below again
    so the top of the screen is at the bottom
    i tryed to change all of the region codes but it doesnt help
    if u can help me i would really apreciate it ^^
    thx
    sandfurz
    Jun 2006
    sounds like a referencing problem. If the game is Japanese it would probably be NTSC so playing it out of a PAL box may be the problem, however it could be the in from the gamecube is out of whack. try running it through a TBC and see if that helps (you could try and use a VHS player etc as your TBC if you don't own one). another thing to try would be to check the settings of your card i.e. fiddle about with which standard is coming in etc. may well help. or maybe not.
    Jul 2006
    Austria
    tried this one
    used a vcr and a dvd-recorder same prob
    but the funny thing is the problem occurs just when its connected to a vcr/dvd-recorder or to the tv-card in my pc
    when its connected to the tv only it works perfectly and thats where i get confused ^^
