Trying to help my friend to remove NAV 2005 from his son's PC.
Couldn't do it using Add/Remove Program. Anyone know how to remove it from the registry ?
Your help will very much appreciated. Thanks.
There is a live unintaller that runs in your browser from symantec's site that will uninstall everything. Unfortunately they make it hard as hell to find the link to it. I recall searching their site for at least an hour before I found it last time.
Thanks @Poppa_Meth,
I found the link...
http://service1.symantec.com/SUPPORT/nav.nsf/docid/2004082712005006
I didn't manage to get it to work.
So I download the Symnrt from here...
http://www.techspot.com/downloads/1437-norton-removal-tool-symnrt.html
I did it with...
1. Stop & disable all NAV & Symantec services at Admin Tools
2. Run Symnrt tool -
Glad you got it resolved. I think the second link is the older tool that worked better. The newer one was a pain and I barely got it to work.
Yes, that works.Originally Posted by pchan
I did the same thing few weeks ago.
I managed to uninstall NAV 2005 with Add/Remove, though, but some Norton stuff remained (WMI Update), so I run Symnrt and all was gone.
I'm testing NOD32 now. Seems better and the computer is more responsive.
I loved NAV and used it for 5 years without a single issue. -
Kaspersky is another good one to test. NOD32 is good but I've heard their support stinks if you ever have to call for anything.
How to get rid of this nav bar
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2012, 21:40 -
Warning : NAV Packets are not detected in video.mpg. Please demultiples
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2008, 22:38 -
dvdauthorgui nav cmds/call menu to different menus?
By ecc in forum Authoring (DVD)Replies: 4Last Post: 23rd Jan 2008, 22:58 -
Clonedvd2 message:NAV error in VOBU,help!
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 04:04 -
What author tool besides GUI For DVDAuthor for mpeg2 files w/o Nav Packs?
By palouse in forum Authoring (DVD)Replies: 7Last Post: 27th Jun 2007, 06:44
